Cannot connect to ethernet
Just downloaded the latest version on my rasp 2, because Openelect has time server problems, which they do not admit, but, I am unable to configure the ethernet either manually, nor automatically. Do I have to download an app?
Nope. I’d try another cable or port on the router.
Time needs an Internet connection on Raspberry Pi.
Once network works; time will too
but, the same cable works on my pc! So do all the ports. I am getting, configuring!
You can either configure the network via the osmc installer, which writes the image to the sd card. Or via MyOSMC which you should be able to see on the Home Screen, as long as you are using the osmc skin.
Thanks Tom.
