Not long had my 4K…i only use it to play movie files from a HD and it works great…When i fast forward a movie it is fine,But i cannot rewind a movie…it just freezes and says “buffering” so i have to stop the movie and then fast forward to the part i want from the beginning…Any tips would be nice.
TIA
Are you familiar with skip steps by using the left/right/up/down keys?
http://kodi.wiki/view/skip_steps
Well thanks to you that brings that question to an end…nice one ActionA…well im 54 now and getting slow…thankyou again for your help and quick reply…i was using the << button at the bottom of the remote
No problem. I think that the <</>> buttons are really just a leftover from our previous times when we were dependent on VHS. FF/RW is really not easily accomplished when the caching of a data stream is the method used to feed a video renderer. Not to mention that it’s a time savings to be able to use skip steps and your own estimation of where you want to go instead of waiting for RW to get to the desired location.
<< and >> wil disappear soon.
