I’m unable to add my I2S soundcard in OSMC. Steps I’ve taken, are:
- Connected the right pins from my DAC to my Raspberry Pi 2 using these instructions:
http://www.tjaekel.com/T-DAC/files/RPi-Bplus_guideline.pdf
- Installed the RC on my SD Card using the installer.
- After booting OSMC on my rapsberry pi 2, performed a software update via My OSMC->Updates
- After reboot, selected iqaudio-dac-overlay (or hfberry-dac-overlay) via My OSMC->Pi Config->Hardware Support->soundcard_dac
- After reboot, went to Settings->System->Audio output->Audio output device.
Problem is that I only see HDMI or analog audio.
Am I missing something?
Kind regards,
Umberto
Are you sure that the DAC version that you have can work on RPi2?
For example - have you had it working using a “regular” Raspbian image from RPF?
Thanks for the tip. I’ll try to get I2S Audio working with the regular raspbian image. Get back to you…
@umberto73 stupid question mate are you clicking ok after you’ve selected the dac that you have I had same problem but all it needed was a couple or reboots and then I could select dac in settings hope this helps
I’m sure I did this (pressing ok). I haven’t tried a couple of reboots.
Just an update: when I use Volumio distribution, my DAC works perfectly. So now I now I have the hardware right.
I’ll try again with OSMC…
Just to let you know; I installed the latest OSMC and it work perfectly!
I’m now one happy OSMC user!
