im using Raspberry pi 3 with OSMC 2017.02-2
When i try to configure the wifi, i insert the password of my network, and the loading logo just run and run, but it never end. On the first configuration happen the same, then i skip and the same.
With wired works fine, its only with the wifi.
Also, sometimes on the network menu, when i hover the wireless option, the screen (only video) stay frozen, but audio works.
Its a clean installation, i dont know if its about the version…
I try to configure the network manually, but the same happen.
im reading the log, and im not sure if this is the error.
Theres a line: SallenPI ftr[253]: returning ({'Passphrase': '12346578'})
And i think thats value of the password of the wifi, then it this other line Jan 01 01:13:36 SallenPI ftr[253]: ReportError /net/connman/service/wifi_b827ebd315ad_646c696e6b_managed_psk, invalid-key
The password is not correct, because its 12345678
There is the now the problem, how its posible i wrote 12345678 (it is no a secuence where make any mistake…) and the value turn the order of the 56 to 65???
I use an usb logitech keyboard.
Any ideas how can be this possible?(i try like 10 times, and wrote wrong that password 10 times, its imposible)
Post your log in the proper place and we can read it, I’m sorry but I have no intention of downloading random files from a random person’s Google drive.
That said you are right that will be the problem line.
Access the console (details of how are in the wiki) the run:
cd /var/lib/connman/
and delete any/all directories starting in wifi using sudo rm -rf wifi_*
i clean tru the console the wifi directories and then try to connect, and the same history.
But, i try first to conect to my “dlink” ssid with 12345678 pass and with the error i try to other wifi, and in the log i didnt see this new ssid (movistar_e362).
Log below. http://paste.osmc.io/ahadifezak
I deactivate the logs, clean again the wifi directories (there was 2) and activate the logs again.
and i try only to connect to the movistar wifi and stuck again http://paste.osmc.io/ehodavipes
i can read in the log is trying to connect to the dlink with a wrong password.
