Yes indeed, I thought that maybe someone had the same issue. I can post the log however I am unsure which one I should select. Is the kernel log sufficient ?
Yes the blue light appears, so I guess the remote works properly. In addition pressing the button can wake up kodi when power save mode. So the command is received by the Vero 4k+.
At the moment the keyboard is configured with the french layout (AZERTY). I tried setting everything back to default but nothing changed.
here are some log outputs:
Feb 23 16:16:13 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:16:13 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:16:13 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:16:13 osmc kernel: hdmitx: audio: no update
Feb 23 16:16:14 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:16:14 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:16:14 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:16:14 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:16:14 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:16:14 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:16:14 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:16:14 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:16:14 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:16:14 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:16:14 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:16:14 osmc kernel: hdmitx: audio: no update
Feb 23 16:16:16 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:16:16 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:16:16 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:16:16 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:16:16 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:16:16 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:16:16 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:16:16 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:16:16 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:16:16 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:16:16 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:16:16 osmc kernel: hdmitx: audio: no update
Feb 23 16:16:17 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:16:17 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:16:17 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:16:17 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:16:17 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:16:17 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:16:17 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:16:17 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:16:17 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:16:17 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:16:17 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:16:17 osmc kernel: hdmitx: audio: no update
Feb 23 16:16:27 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:16:27 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:16:27 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:16:27 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:16:27 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:16:27 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:16:27 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:16:27 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:16:27 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:16:27 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:16:27 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:16:27 osmc kernel: hdmitx: audio: no update
Feb 23 16:16:29 osmc sudo[2337]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl
Feb 23 16:16:29 osmc sudo[2337]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 23 16:16:29 osmc sudo[2337]: pam_unix(sudo:session): session closed for user root
Feb 23 16:17:09 osmc kernel: audio_dsp: buf=0
Feb 23 16:17:09 osmc kernel: audio_dsp: IEC958_mode_raw=0
Feb 23 16:17:09 osmc kernel: audio_dsp: IEC958_mode_codec= 1, IEC958 type 2 CH PCM
Feb 23 16:17:09 osmc kernel: audio_dsp: last mode 1,now 1
Feb 23 16:17:09 osmc kernel: audio_dsp: putting chip back to PCM state
Feb 23 16:17:09 osmc kernel: hdmitx: config: audio_on
Feb 23 16:17:09 osmc kernel: hdmitx: audio: configure on
Feb 23 16:17:09 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:17:09 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:17:09 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:17:09 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:17:09 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:17:09 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:17:09 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:17:09 osmc kernel: hdmitx: audio: no update
Feb 23 16:17:09 osmc kernel: sysfs set hdmi_ch to 0
Feb 23 16:17:09 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:17:09 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:17:09 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:17:09 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:17:18 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:17:18 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:17:19 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:17:19 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:17:19 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:17:19 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:17:19 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:17:19 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:17:19 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:17:19 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:17:19 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:17:19 osmc kernel: hdmitx: audio: no update
Feb 23 16:17:20 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Feb 23 16:17:20 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Feb 23 16:17:20 osmc kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback disable
Feb 23 16:17:20 osmc kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback disable
Feb 23 16:17:20 osmc kernel: i2s/958 same source - init spdif
Feb 23 16:17:20 osmc kernel: aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1), stream format=1
Feb 23 16:17:20 osmc kernel: aml_spdif_dai: set divider = 2 for i2s shared clock
Feb 23 16:17:20 osmc kernel: aml_audio_hw: IEC958 PCM32
Feb 23 16:17:20 osmc kernel: hdmitx: audio: aout notify rate 44100
Feb 23 16:17:20 osmc kernel: hdmitx: audio: aout notify size 32
Feb 23 16:17:20 osmc kernel: hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
Feb 23 16:17:20 osmc kernel: hdmitx: audio: no update
