Hello there!
I had Vero 4k for quite some time and it was working fine.
I’ve just updated my HDD from a 2To WD to a 4To WD, both are Mac OS Extended (Journaled) format.
But with the new 4To, first, it is really slow to access files on the Vero, and when I do access my files, it can’t read them. There’s the loading Logo, “Please wait…” and that is it.
Can someone figure out what is wrong?
Not Without:
reproduce the issue
upload the log set (all configs and logs!) either using the
Are you powering the drive with an external power supply or USB hub?
Thank you both for you replies:
@Tom_Doyle, I’m trying to upload but stuck on “Retrieving diskpace”. Via SSH, here is the link
https://paste.osmc.tv/diwanufufe
@sam_nazarko, via USB only
You need to power the drive properly or it won’t work.
Logs suggest that the drive isn’t getting enough power.
Oh ok, so I can’t use it with my Vero?
Probably not without a powered usb hub. I use and can recommend the one available in the store:
Thanks Tom.
Thank you
