Hi everyone,
My goal is to have Samba server running on my CB2 all the time. This means that whenever I reboot my CB2, I want Samba to start and continue running. The issue is that currently Samba does not start when CB2 boots. So I started investigating. As far as I can read online, in CB2 Samba is launched within xinetd. When I reboot my CB2, I can see that xinetd is running, yet samba processes are not.
Then I dug deeper. I looked at whether samba is present at /etc/xinetd.d/ and whether xinetd.conf is correct. Below we can see that the samba file is there and configuration should be correct (as far as I can tell - maybe there’s something wrong here?).
atv@appletv:~$ ls /etc/xinetd.d/
chargen daytime discard echo ftp samba ssh time
atv@appletv:~$ sudo nano /etc/xinetd.d/samba
service netbios-ssn
disable = no
id = netbios-ssn
# port = netbios-ssn
socket_type = stream
protocol = tcp
user = root
wait = no
instances = 2
server = /usr/sbin/smbd
service netbios-ns
disable = no
id = netbios-ns
# port = netbios-ns
socket_type = dgram
protocol = udp
user = root
wait = yes
instances = 1
server = /usr/sbin/nmbd
tv@appletv:~$ sudo nano /etc/xinetd.conf
# Simple configuration file for xinetd
# Some defaults, and include /etc/xinetd.d/
defaults
# Please note that you need a log_type line to be able to use log_on_success
# and log_on_failure. The default is the following :
# log_type = SYSLOG daemon info
includedir /etc/xinetd.d
Then I tried to manually stop and start xinetd in hope that it would start Samba, but unfortunately it does not start samba. The xinetd process runs though.
atv@appletv:~$ sudo initctl stop xinetd
atv@appletv:~$ sudo initctl start xinetd
atv@appletv:~$ ps aux
root 1470 0.0 0.3 2560 984 ? Ss 13:51 0:00 /usr/sbin/xinetd -dontfork -pidfile /var/run/xinetd.pid -stayalive -inetd_compat -inetd_ipv6
Next, I tried to just check whether samba will run if I start it manually. So I run the following two commands, and to my surprise both samba processes started and samba run successfully - I can successfully access the samba share from OS X Finder:
atv@appletv:~$ sudo /usr/sbin/smbd
atv@appletv:~$ sudo /usr/sbin/nmbd
root 4643 0.0 1.3 21396 3384 ? Ss 13:26 0:00 /usr/sbin/smbd
root 4645 0.0 0.5 21500 1340 ? S 13:26 0:00 /usr/sbin/smbd
root 4670 0.0 0.7 13320 1772 ? Ss 13:27 0:00 /usr/sbin/nmbd
This all suggests that the issue lies within xinetd , because it simply does not start the two Samba processes. Can someone please tell me what could be the cause for this? Where should I check what services xinetd actually starts? Perhaps xinetd does not start any processes at all (not only samba). I am ready to provide any extra information necessary. Thanks!
