Cec error messages in log
Installed OSMC on a friends pi.
In the kodi.log i see loads of these messages - recurring …
17:09:12 570.321899 T:1853842416   ERROR: CecLogMessage - could not open a connection (try 1)
17:09:13 571.322632 T:1853842416   ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:09:13 571.326904 T:1853842416   ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:09:13 571.326965 T:1853842416   ERROR: CecLogMessage - could not open a connection (try 2)
17:09:14 572.323853 T:1853842416   ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:09:14 572.324036 T:1853842416   ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:09:14 572.324158 T:1853842416   ERROR: CecLogMessage - could not open a connection (try 3)
any ideas ?
thanks
Either his TV doesn’t support CEC; his AV receiver doesn’t or his HDMI cable does not have pin 13 wired.
It’s nothing to worry about. But you would benefit from disabling CEC.
got it thanks - I have SSH access - can I disable CEC from the command line?
I tried putting a line into config.txt but that didn’t work.
guess i need to do it in guisettings but I don’t see a CEC line.
There is no advancedsettings file on the machine as i see it.
if not no problem will do it via the gui at some point.
You’re probably right about the TV, ancient - am surprised it has an HDMI socket at all.
ta
I think it’s under Input -> Peripherals.
If you leave it on, it won’t cause problems, but it will spam the hell out of the log.
