so if i let the RPi2 go to dim screen then my TV remote stops being detected by the RPi2.
BUT if i connect to RPi2 using a smartphone remote app, push any button in the app, the screen “undim” and my TV remote starts to be detected.
This issue still persists in latest version after update december 2015.
No CEC response on raspberry PI 2B untill other devices (keyboard)
input is received. My gut tells me its because of the /dev/mouse hovering after dim leaving
no active selection in menu interface therefore deactivating CEC response. As these are two separate processes in the interface.
I’ve seen this issue a few times myself but I find if you hit the left/right/up or down button on the remote a few times the Pi2 comes back to life!!! I think I once fixed it hitting the Simplink button too…
PS That’s an LG TV…
LG are reknowned for their crappy CEC implementation - one of my TV’s is an LG and the CEC doesn’t work reliably on any device including a Fire TV stick.
As soon as I switch the TV off and on CEC stops working. Do some googling for LG and CEC/simplink and you’ll find lots of people complaining about it.
My Samsung TV on the other hand, CEC works perfectly on all devices. If CEC is important to you, don’t buy LG. I certainly won’t be buying another one.
