OK, so maybe this might not be an OSMC or Kodi issue, but I have to start somewhere…
My RPi 1B is connected to a 2009(ish) Sony Bravia. OSMC is a fresh install. OSMC’s CEC settings have been set to not turn off the TV when I shut down.
So, I select to Power off system from the menu and wait for the RPi to shut down (all the lights go off except for the red power one)
When it’s powered down I find that CEC/BraviaSync is behaving strangely - eg, turning the TV off will not turn off my AV amp as it should. Also, if I leave the TV on and go to another input, I find that the TV constantly resets (screen goes blank and Sony logo appears).
If I unplug the HDMI cable from the RPi then all of these problems go away, so there’s obviously something amiss with the RPi (I have also tried 3 different HDMI cables, btw)
Like I said, this probably isn’t an OSMC/Kodi issue, but I was hoping someone out there might have come across the same issue!
Peter
PS: Unlike some forum posters, I have absolutely no issues with CEC control and OSMC - works like a charm when the system is running!
Yes, I did know that, and thanks for the suggestion, but there are times when the Pi will need to be shut down, so that doesn’t really address the problem!
Removed/powered down, can have no active effect on the TV. It must be an issue with the TV’s handling of CEC. There have been tons of reports of issues with BraviaSync and not just concerning RPI. You might want to investigate that aspect.
Yes, that’s my thinking too. But, seeing as I don’t have any trouble with my other devices (CEC & non-CEC) - only the Pi - I thought I’d start by seeing if anyone else has had a problem. Thanks.
