Hello,
It looks like CEC stopped working after the updates released yesterday (5th of Feb).
Does anyone know ho to fix that?
I use it on Raspberry pi3
Thanks,
Lucas
Hello,
Thanks,
Lucas
Did you read the Krypton update faq at the top of the forum?
Have you tried the suggested fix there?
I had the same problem. I’ve done a new manual update check, and an update was available. Ran this update and everything works fine now
No problem on my side.
Maybe disable/ re enable CEC service will work
I can confirm that CEC is working again after another update was installed.
Thanks for help,
Lucas
