Hi, I have a problem with a RPI2 and the CEC module. Every time I reboot the Pi or I do a clean boot the Pi/OSMC triggers my projector and powers it up. I set the option not to anything on start in the CEC module but it doesnt help. I also cant deactivate the CEC module as I am using it
Any ideas on this?
Please try to disable “Beim Starten, Kodi als aktive Quelle melden”. But I’m not sure if cec will work after that…
Does it solve your problem?
