CEC problems after update with Kodi v17 Krypton (Jan update)
After installation of the Jan update I experience funny behavior of remote control using the TV remote control. Cursor moves more than one time up/down/left right after pressing one time up/down/ left or right. I.e. When pressing on video’s menue item to file menu item it jumps to the power button at lower left corner and not to the file buton. Or sometimes it jumps to the file menu then followed by jump back to video menu item. I use confluence as skin.
It does do the jumps randomly. I have played with settings in de CEC interface settings for the 3 menu items dealing with delay etc, but none had any influence on the behavior.
Rolled back to November update which works fine??
Searched OSMC and Kodi forum for similiar problems but did not found resolution
Any suggestions?
Config Raspberry Pi B
I’ve had a similar issue which forced me to rollback to November update as well, sad but true… Haven’t found any other solution
Problem still remains after March update.
Any suggestions???
