The “Change Audio” menu while the movie is playing behaves incorrectly. Let’s say that the movie is playing in ENGLISH at startup. Then I go to the menu and I want to change the language to ITALIAN. Now everything is OK and the movie “talks” in ITALIAN. But if I go back to the menu to change the audio again, it already says ENGLISH (but the movie is still in ITALIAN). Here even if I select ENGLISH… the language won’t change. I have to select ITALIAN… and then (without leaving the menu) I have to select ENGLISH again for the movie to talk in ENGLISH.
Just a error report.
Which skin are you using? Is it the same with all skins?
