Choppy/slow playback on some movies
Hi all,
apologies if this has been discussed before, I did look but couldn’t find anything that matched my problem.
I have the November release of OSMC (Kodi 15.2) on a Pi 2, reading mkv files sitting on a NFS source provided by a box running OMV. The connection is wired using the internal house LAN.
I have half a dozen movies that when I try and play them behave oddly. The sound seems fine but the picture is slow, (looks like it’s in slow motion), and there are artefacts showing, mostly on scene changes.
All the other movies (150+ of them) play absolutely fine, it’s just these 6. Strangely on one of the movies, (I Am Legend), the theatrical version plays fine but the ‘alternate ending’ version suffers from this problem.
None of the movies that suffer from this problem play fine at any point, the picture runs slow right from the off.
In each case all of the movies play absolutely fine from VLC on my PC, (the machine I used to rip the movies from blu-ray), either from a local disc or using an SMB share on the OMV box.
I’ve tried re-ripping a couple of the movies to see if it was a bad rip but get the same problem.
I’ve left most of the settings on default except to tell OSMC about the AV box and its audio capabilities.
Happy to prvide as much info on settings as required…hoping someone can help!
Mediainfo on a problem file would be helpful.
Thanks for replying so quickly ActionA.
I’m a newbie so apologies if I’m making an incorrect assumption, but have used MediaInfo from MediaArea.net to get what I hope is what you need.
Dumped the details from to a text file for Batman Begins, pasted below. Can do it another way/format if that’s better, just say the word.
General
Unique ID : 54012460729897702418894578216194432537 (0x28A26BEAA235223DD1D790EA751A5E19)
Complete name : D:\Video\BATMAN_BEGINS\Batman Begins.mkv
Format : Matroska
Format version : Version 2
File size : 17.5 GiB
Duration : 2h 20mn
Overall bit rate : 17.9 Mbps
Encoded date : UTC 2015-12-28 12:50:19
Writing application : MakeMKV v1.9.7 win(x64-release)
Writing library : libmakemkv v1.9.7 (1.3.0/1.4.1) win(x64-release)
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 2h 20mn
Bit rate : 13.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.275
Stream size : 13.4 GiB (77%)
Language : English
Default : No
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Delay relative to video : 125ms
Stream size : 641 MiB (4%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate : 640 Kbps
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate : 640 Kbps
Language : French
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate : 640 Kbps
Language : German
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate : 640 Kbps
Language : Italian
Default : No
Forced : No
Audio #6
Format : AC-3
Codec ID : A_AC3
Duration : 2h 20mn
Bit rate : 640 Kbps
Language : Spanish
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : French
Default : No
Forced : No
Text #3
Format : PGS
Language : German
Default : No
Forced : No
Text #4
Format : PGS
Language : German
Default : No
Forced : No
Text #5
Format : PGS
Language : Italian
Default : No
Forced : No
Text #6
Format : PGS
Language : Italian
Default : No
Forced : No
Text #7
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #8
Format : PGS
Language : Dutch
Default : No
Forced : No
Text #9
Format : PGS
Language : Danish
Default : No
Forced : No
Text #10
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #11
Format : PGS
Language : Norwegian
Default : No
Forced : No
Text #12
Format : PGS
Language : Portuguese
Default : No
Forced : No
Text #13
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #14
Format : PGS
Language : French
Default : No
Forced : No
Text #15
Format : PGS
Language : German
Default : No
Forced : No
Text #16
Format : PGS
Language : Italian
Default : No
Forced : No
Text #17
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:03:38.885 : en:Chapter 02
00:07:30.950 : en:Chapter 03
00:11:33.859 : en:Chapter 04
00:16:15.391 : en:Chapter 05
00:19:44.016 : en:Chapter 06
00:24:19.207 : en:Chapter 07
00:28:24.452 : en:Chapter 08
00:31:25.049 : en:Chapter 09
00:35:53.568 : en:Chapter 10
00:38:24.385 : en:Chapter 11
00:41:14.388 : en:Chapter 12
00:43:08.252 : en:Chapter 13
00:46:57.648 : en:Chapter 14
00:49:43.730 : en:Chapter 15
00:53:25.911 : en:Chapter 16
00:55:55.018 : en:Chapter 17
00:58:02.020 : en:Chapter 18
01:03:31.808 : en:Chapter 19
01:05:53.032 : en:Chapter 20
01:08:38.781 : en:Chapter 21
01:11:25.614 : en:Chapter 22
01:13:19.228 : en:Chapter 23
01:16:16.238 : en:Chapter 24
01:19:50.285 : en:Chapter 25
01:23:54.070 : en:Chapter 26
01:29:02.503 : en:Chapter 27
01:32:36.425 : en:Chapter 28
01:37:49.029 : en:Chapter 29
01:40:33.610 : en:Chapter 30
01:45:08.635 : en:Chapter 31
01:49:31.898 : en:Chapter 32
01:51:29.015 : en:Chapter 33
01:54:48.798 : en:Chapter 34
01:58:11.000 : en:Chapter 35
02:01:54.640 : en:Chapter 36
02:05:01.160 : en:Chapter 37
02:06:06.892 : en:Chapter 38
02:09:18.333 : en:Chapter 39
02:10:57.015 : en:Chapter 40
This video uses the VC-1 codec - you’ll need to buy and install the VC-1 codec license from the Raspberry Pi foundation to be able to play it with hardware accelerated decoding.
DBMandrake,
once again thanks for the quick reply!
I’ve ordered the license key, just waiting for it to arrive.
Apologies for raising what appears to be such a trivial problem, at least I now know what else to look for.
Both,
thanks again for the assistance, once the license was added and OSMC rebooted they all worked just fine.
That was fast !
It normally takes 24 hours to get the codec license and after posting I noticed the link I gave you said they were closed until January 4th… :smile:
Glad it sorted it for you.
Yup, it sure was…saw the same message as you so didn’t expect to see the license until next week!
Perhaps creating the keys is an automated process, or maybe someone was full of Christmas spirit and took pity on me :slightly_smiling:
Thanks again.
