I have 2 Pi’s running OSMC, both are up to date, both are connected via wired ethernet and both mount the same library media via NFS - the fstabs on both devices are identical, as are the skins and config.
The only significant difference between them is that device A is a Pi 2, and device B is a Pi 1 [model B with 512k].
I’ve been thinking about setting them up with a shared library DB, but at present each uses their own local DB.
If I select ‘Clean Library’ [even when there have been no library changes], Pi A takes ~10mins, whereas Pi B takes < 1 min to scan the same library.
Other than this both are working fine. Any ideas why the Pi 2 should be so much slower than the less powerful Pi ?
