Clean library
Hi all,
Today I noticed that my Pi3/OSMC had several recorded TV programs in the library that I had previously deleted from my backend using a different device. I decided to use the “clean library” function from within the Pi3/OSMC to remove them. It didn’t work. After “cleaning”, the programs were still in the library.
Is there something I’m doing wrong here or something I’m missing?
Thanks for any assistance.
Yes. Debug logs. Or it didn’t happen :wink:
Set debug logging in Kodi and try another clean. Then post logs. Please also tell us which programmes are the ones causing problems.
Oh, and welcome back!
Touche! :smiley: I should have known better. I’ve cleaned things up manually for now but I’ll watch for this to happen again and post proper logs and provide program information if it does.
Thank you! It’s great to be back! I’m having fun now that my wifi problem is sorted.
