Hi all, I’ve searched the forums for similar post but did not see one
I’m following the steps in the Kodi guide in the link below to refresh my library as I changed ISP recently and my NAS IP address changed with the new router, so I’ve got to the last step after removing the old sources and re-add the new sources (NFS shares):
https://kodi.wiki/view/Updating_or_removing_videos#Remove_Source
However my Vero freezes on the very last step of removing all and I’m not sure if I can fix this through the UI, maybe I need to run some commands or delete some files from profile Database, appreciate any help offered, thank you!
reproduce the issue
I’ve deleted some of the DB files and started to build the library again.
Let us know if that solves the issue
