Hi guys,
I’ve just noticed that my kodi logs are full of errors like this one
COMXImageFile::GetCodingType progressive images not supported by decoder
Someone can help me on that topic to find the root cause?
I’m using Artic Zephyr as skin and pictures are coming from extrafanart.
21:17:26 95520.187500 T:1178067952 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
21:17:26 95520.210938 T:1178067952 WARNING: Previous line repeats 1 times.
21:17:26 95520.226562 T:1178067952 NOTICE: LoadJpeg: unable to load smb://LACIE-CLOUDBOX/Family/TV Shows/Dark Net/extrafanart/1116983.jpg
It means the VideoCore cannot accelerate the decode of the JPEG, so it must go to the ARM. This had a more significant impact in the days of Pi 1, but with a Pi2/Pi3 this isn’t much of an issue anymore.
It means that loading the images will be slower, but it’s not really an error. It should probably be changed to a warning instead.
Edit: I skimmed that, but after seeing your log again (and checking the CLog call), I can see it’s already a Warning, not an error.
Thanks @sam_nazarko for this fast answer, like always
I’m on pi3 and yes, I don’t feel any impact but I’m checking freqently my logs to try to reduce errors.
Is there something I can do against that? Except reprocessing the picture manually?
I don’t think so – the issue is with the source of the image.
So without re-encoding it, it won’t change the situation. But it doesn’t matter about the logging. It’s not an error and it’s not causing any problems.
