I am running a RPi3 with IQaudio DAC+ hat which is being used as a music renderer.
I have this working with a wifi connection to an hidden SSID by setting up the wpa_supplicant.conf with the details of this SSID and password included in the configuration file.
I now need to move the device so that it connects to a different hidden SSID.
Is there any easy way to move back and forth between the two locations or do I have to edit the .conf file each time. I am only able to work using ssh in an headless setup.
A quick google search has led to believe (I’ve not tested, but it may be worth trying), you can create multiple .config files in /var/lib/connman/ for each connection. In theory it should just connect to the available hidden ssid.
Hi Sam et al. Working from cli I looked for connmanctl. It is not installed. I have no idea why not as history of this device has been primarily to keep my music playing at home.
Am I due some sort of upgrade or an installation of new app. Please advise.
Further to the above I checked my system and it seemed reasonably up to date. Here is my last upgrade. Not sure about the error on the last lines.
Blockquote
abr@IQaudio-DAC-2:/ $ sudo apt-get dist-upgrade
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
libntfs-3g883 libssl1.1 ntfs-3g openssl rpi-eeprom
5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,450 kB of archives.
After this operation, 503 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:2 Index of /debian buster/main armhf rpi-eeprom armhf 12.12-1 [833 kB]
Get:1 Index of /raspbian/raspbian buster/main armhf ntfs-3g armhf 1:2017.3.23AR.3-3+deb10u1 [378 kB]
Get:3 Index of /raspbian/raspbian buster/main armhf libntfs-3g883 armhf 1:2017.3.23AR.3-3+deb10u1 [168 kB]
Get:4 Index of /raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u7 [1,263 kB]
Fetched 3,450 kB in 32s (108 kB/s)
Reading changelogs… Done
Preconfiguring packages …
(Reading database … 42119 files and directories currently installed.)
Preparing to unpack …/ntfs-3g_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb …
Unpacking ntfs-3g (1:2017.3.23AR.3-3+deb10u1) over (1:2017.3.23AR.3-3) …
Preparing to unpack …/libntfs-3g883_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb …
Unpacking libntfs-3g883 (1:2017.3.23AR.3-3+deb10u1) over (1:2017.3.23AR.3-3) …
Preparing to unpack …/libssl1.1_1.1.1d-0+deb10u7_armhf.deb …
Unpacking libssl1.1:armhf (1.1.1d-0+deb10u7) over (1.1.1d-0+deb10u6+rpt1) …
Preparing to unpack …/openssl_1.1.1d-0+deb10u7_armhf.deb …
Unpacking openssl (1.1.1d-0+deb10u7) over (1.1.1d-0+deb10u6+rpt1) …
Preparing to unpack …/rpi-eeprom_12.12-1_armhf.deb …
Unpacking rpi-eeprom (12.12-1) over (12.11-1) …
Setting up libssl1.1:armhf (1.1.1d-0+deb10u7) …
Setting up libntfs-3g883 (1:2017.3.23AR.3-3+deb10u1) …
Setting up ntfs-3g (1:2017.3.23AR.3-3+deb10u1) …
Setting up rpi-eeprom (12.12-1) …
Setting up openssl (1.1.1d-0+deb10u7) …
Processing triggers for libc-bin (2.28-10+rpt2+rpi1) …
Processing triggers for man-db (2.8.5-2) …
Processing triggers for initramfs-tools (0.133+deb10u1) …
W: http://mirror.mythic-beasts.com/raspbian/raspbian/pool/main/o/openssl/libssl1.1_1.1.1d-0+deb10u7_armhf.deb: Automatically disabled Acquire::http::Pipeline-Depth due to incorrect response from server/proxy. (man 5 apt.conf)
Tried to install connman and it has stalled during installation and I no longer am able to access the device. Seems like it is no longer connected.
Ooops!
Raspbian to SD card then took it from there.
Sudo raspi-config for initial setup.
set hostname=IQaudio-DAC-1, ssh enabled, locale en-GB UTF-8,
Initial network set for DHCP and on my home network getting IP; rebooting gives login for pi.
Then downloaded and installed lesbonscomptes upmpcli Rpi security key and repo list and after updating and upgrading installed mpd and then upmpdcli and sc2mpd.
