I’d like to use a 6TB WD Elements 2.5" HDD on my Vero 5, connected via a micro USB Type B cable. Unfortunately, the drive experiences intermittent issues on both USB ports of the Vero. The problem was worse on my Vero 4 than on the Vero 5, but stable operation isn’t possible on the Vero 5 either. Does anyone recognise this problem and perhaps know a solution?
So far, I’ve been using a simple, 30cm-long micro USB Type B to USB-A cable.
The problem is trying to use that type of drive on almost any non PC device. That drive in particular can have peak power consumption twice as high as the USB 3 spec allows for which is almost four times as much as USB 2 allows for. USB ports on a PC are frequently over spec’d so it doesn’t cause an issue. However on most other devices the excessive current demands mean that either the drive gets starved for power and can’t startup correctly (common symptom being a clicking sound) or it trying to spin up the drive causes a voltage sag on the entire device and the device you plugged it into crashes.
To use this type of device you likely will have to at minimum power it through a Y cable (one plug to the hard drive, one plug to USB 3 for power and data, one plug to USB 2 for extra power), but more likely need to run it through a powered USB hub that allows for a higher current draw.
That was exactly what I was afraid of. According to the internet, the drive requires up to 1.8A, which is, of course, too much for the Vero’s power supply. I’m going to try connecting it to both ports on the Vero using a Y-cable, and if that doesn’t work, I’ll use the second branch of the Y-cable with an external power supply or a USB hub. What cable do I need for the Vero itself? Then I’d power the Vero using a USB-A to the appropriate round plug, and power the drive via the second USB-A connector on the Y-cable.
I realised that I needed to connect the USB-A to round plug (5.5 mm × 2.1 mm) and the micro USB Type B to 2 × USB-A Y-cable to a USB power supply with at least 30 watts.
Do NOT try to power that device where you have power coming in from two different power sources. Y cables should only ever be used to split current load between USB ports on the same device. If you go with a powered hub just plug the drive into it and then plug the hub into the Vero. If you really need to save that power socket and only have a single power source some hubs will back power from the plug you put into the computer, but they usually don’t, and they shouldn’t. You can use a USB to barrel jack cable like this one to feed power to a Vero from a hub without having an issue of two data sources from the hub trying to talk to the Vero…
Can you connect the hard drive to a PC’s USB port and very carefully wiggle the cable slightly at the drive’s port? If it loses power then, it could be the same problem.
No, it works perfectly and without any issues on the PC. The problems only occur on the Vero – which makes sense, given the power supply.
Regarding the cable: is it possible to separate the data transfer and the power supply on a micro USB Type B connector? In other words, to use one micro USB plug for data transfer and the other plug (whatever type it is) for the power supply? That way, the power would come exclusively from a single power source, but one that can also deliver more power. There would then be two separate cables connected to the WD Elements, rather than a single Y-cable.
I think their exist power injector cables and boxes that do this, and someone adventurous could always hack together their own, but to what end? Powered Hubs are redably available and can be found at reasonable prices. They feed power to the devices plugged into them and connect just the data lines to the upstream device. They typically don’t try to limit current, so as long as they have a big enough power supply connected to them they will usually happily power out of spec devices without issue.
I wouldn’t do that as others mentioned will suck too much energy. The wd may even will burn. Had it actually when i had no hub that wd drive went up in smoke.
Just buy an usb hub which is external powered. I have wd drives too and i am using since years the Icy Box IB-HUB1405. I plugin all my wd’s into that hub and the hub to vero. Plugin the usb storage directly in vero will make trouble. That’s why a hub is really needed.
As I’d really only need the hub for that one hard drive, do you have any good recommendations for a hub that’s as small as possible and has as few USB ports as possible?
So I really must ask again whether it’s possible that either the Vero V or the remote control is faulty.
The HDD is connected via an active hub to the USB 2 port, and both the hub and the hard drive are situated well away from and behind the Vero. The remote control has a brand-new battery and I’ve reconnected it.
And everything works fine with Yatze and via my LG’s remote control.
It’s just the Vero V’s remote control that’s unresponsive: some commands are ignored and sometimes two commands are executed at once. It’s really annoying.
Yatze and CEC use completely different communication systems than your OSMC remote so having an issue with one of them that doesn’t exist on the others doesn’t really tell you anything. Do you have anything plugged into the USB 3 port on the Vero or do you have any other devices close to the Vero that transmit bluetooth or wifi? How far away are you from the Vero when the remote starts acting up? Does it work reliably when you are only a meter away?
