if it´s a way for increase the WIFI speed,i want to try,i don´t know what is happening using cable
You are unwise to be posting your home IP publicly like this!
if i restart the router the ip will change dont worry xD
(if you have the domain name,you have the ip…then you have to edit the name of my domain too xD)
Is already changed,any idea?
Ok, let’s just clarify exactly what the situation is now so that we can go forward, please answer all the questions below:
- Are you using a cable connection or WiFi?
- Have you unplugged/disabled the other interface?
- What is the local IP of the interface you’re using? (192.168.1.?)
- What service are you trying to connect to on OSMC? The kodi remote?
Please also do the following:
- Enable debug logging inMyOSMC.
- Reboot Pi
- Recreate problem.
- Upload new logs.
- Post all this information along with a screenshot of the port forward screen of your router.
-I am using cable because WIFI is slow streaming in Chorus WebServer
-Yes,is DISABLED
-192.168.1.150
-I am trying to connect to the web server,to VNC…nothing works(but Yatse the kodi remote APP is working and SSH too because i am using the LAN IP: 192.168.1.150)
-I am searching and can´t find any “debug logging” thing
-Rebooted
-Trying to connect to WebServer and VNC again(dont work)
-Getting logs via SSH
Logs
-Screenshot of router
If i use WIFI,all works fine,but have low streaming speed,if you want to see by yourself ask me about user and password,then you will see the problem
Thank you, that gives us a good starting point.
What are you running on port 8080? Is it the kodi web interface or a separate web server?
Can you access http://192.168.1.150:8080/ from inside your network ok?
Can you post the output of sudo iptables -L
Also please try the following and post the output here.
sudo apt-get update && sudo apt-get install netstat
sudo netstat -al
Does your router or your ISP have a firewall active?
thanks for your time
-Port 8080 is the Kodi WebServer
-I can access to WebServer using 192.168.1.150 w/o problem,and stream files with good quality and speed
sudo apt-get update && sudo apt-get install netstat : all done but “E: Unable to locate package netstat”
sudo netstat -al:
I don´t know how to hide the text in a word,sorry
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 :5900 : LISTEN
tcp 0 0 :2222 : LISTEN
tcp 0 0 :sunrpc : LISTEN
tcp 0 0 :http-alt : LISTEN
tcp 0 0 osmc:52307 : LISTEN
tcp 0 0 :36666 : LISTEN
tcp 0 0 :1410 : LISTEN
tcp 0 216 RaspiMultimedia:2222 192.168.1.37:50397 ESTABLISHED
tcp 0 0 RaspiMultimedi:http-alt 192.168.1.37:50426 ESTABLISHED
tcp6 0 0 [::]:5900 [::]: LISTEN
tcp6 0 0 [::]:2222 [::]: LISTEN
tcp6 0 0 [::]:sunrpc [::]: LISTEN
tcp6 0 0 [::]:http-alt [::]: LISTEN
tcp6 0 0 [::]:36666 [::]: LISTEN
tcp6 0 0 [::]:36667 [::]: LISTEN
tcp6 0 0 [::]:9090 [::]:* LISTEN
tcp6 0 0 192.168.1.150:9090 192.168.1.37:50368 ESTABLISHED
udp 0 0 *:14090 :
udp 0 0 *:1900 :
udp 0 0 :1011 :
udp 0 0 RaspiMultimedia:54798 51-254.dsl.data.:domain ESTABLISHED
udp 0 0 :9777 :
udp 0 0 RaspiMultimedia:34891 250.red-80-58-61:domain ESTABLISHED
udp 0 0 :33884 :
udp 0 0 :sunrpc :
udp 0 0 RaspiMultimedia:ntp :
udp 0 0 osmc:ntp :
udp 0 0 :ntp :
udp 0 0 :mdns :
udp6 0 0 [::]:1011 [::]:
udp6 0 0 [::]:36946 [::]:
udp6 0 0 [::]:sunrpc [::]:
udp6 0 0 osmc:ntp [::]:
udp6 0 0 [::]:ntp [::]:
udp6 0 0 [::]:mdns [::]:
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 DGRAM 9483 /run/user/1000/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 9485 /run/user/1000/systemd/private
unix 2 [ ACC ] STREAM LISTENING 11362 /var/tmp/osmc.settings.sockfile
unix 2 [ ACC ] STREAM LISTENING 6770 /var/run/lirc/lircd
unix 2 [ ACC ] STREAM LISTENING 8608 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 8611 /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 7095 /run/rpcbind.sock
unix 2 DGRAM 1213 /run/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 1215 /run/systemd/private
unix 2 DGRAM 1227 /run/systemd/shutdownd
unix 12 DGRAM 1232 /run/systemd/journal/dev-log
unix 2 [ ACC ] SEQPACKET LISTENING 1236 /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 1240 /run/systemd/journal/stdout
unix 6 DGRAM 1242 /run/systemd/journal/socket
unix 2 [ ACC ] STREAM LISTENING 9409 /var/tmp/osmc.settings.update.sockfile
unix 3 STREAM CONNECTED 5772
unix 2 DGRAM 9472
unix 3 DGRAM 9397
unix 3 STREAM CONNECTED 11418 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 5767
unix 2 DGRAM 9292
unix 3 STREAM CONNECTED 10512 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 9494
unix 3 STREAM CONNECTED 9310
unix 3 STREAM CONNECTED 11371 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 9465
unix 3 STREAM CONNECTED 9493
unix 3 STREAM CONNECTED 9311
unix 3 STREAM CONNECTED 11370
unix 3 STREAM CONNECTED 10513 /var/run/dbus/system_bus_socket
unix 2 DGRAM 5765
unix 3 DGRAM 9389
unix 3 STREAM CONNECTED 5768
unix 2 DGRAM 9464
unix 3 DGRAM 9393
unix 3 STREAM CONNECTED 11349 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 11348
unix 3 DGRAM 9392
unix 3 STREAM CONNECTED 5877
unix 3 STREAM CONNECTED 11352 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 6888 /run/systemd/journal/stdout
unix 3 DGRAM 1318
unix 3 DGRAM 1319
unix 3 DGRAM 9390
unix 3 STREAM CONNECTED 9377
unix 2 DGRAM 5836
unix 3 STREAM CONNECTED 10503 /run/systemd/journal/stdout
unix 2 DGRAM 1258
unix 2 STREAM CONNECTED 9289
unix 3 STREAM CONNECTED 11316
unix 3 STREAM CONNECTED 7491 /var/run/dbus/system_bus_socket
unix 2 DGRAM 1315
unix 3 DGRAM 9396
unix 3 STREAM CONNECTED 7405
unix 3 STREAM CONNECTED 10797
unix 3 STREAM CONNECTED 7444
unix 3 STREAM CONNECTED 7508
unix 2 STREAM CONNECTED 10912
unix 3 STREAM CONNECTED 6675 /run/systemd/journal/stdout
unix 2 DGRAM 10590
unix 3 STREAM CONNECTED 7489 /var/run/dbus/system_bus_socket
unix 2 DGRAM 7493
unix 3 STREAM CONNECTED 6043 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 8619
unix 3 STREAM CONNECTED 7533
unix 3 STREAM CONNECTED 7530
unix 3 STREAM CONNECTED 6920 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 8774
unix 3 STREAM CONNECTED 6676 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 6050 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 6908 /run/systemd/journal/stdout
unix 2 DGRAM 10804
unix 3 STREAM CONNECTED 7487
unix 3 STREAM CONNECTED 9466 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 7482
unix 3 STREAM CONNECTED 7534
unix 3 STREAM CONNECTED 6053 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 7509 /var/run/dbus/system_bus_socket
unix 2 DGRAM 8622
unix 3 STREAM CONNECTED 7578
unix 2 DGRAM 10915
unix 3 STREAM CONNECTED 6677 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 7490 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 8628
unix 3 STREAM CONNECTED 7488
unix 3 STREAM CONNECTED 10511 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 7898
unix 3 STREAM CONNECTED 8879 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 7681
unix 3 STREAM CONNECTED 11347 /var/run/lirc/lircd
unix 3 STREAM CONNECTED 7755
unix 2 DGRAM 7753
unix 3 STREAM CONNECTED 9227 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 6910
unix 3 STREAM CONNECTED 8929 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 7087
unix 3 STREAM CONNECTED 6765
unix 2 DGRAM 6949
unix 3 STREAM CONNECTED 8678 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 6950
unix 3 STREAM CONNECTED 6843
unix 3 STREAM CONNECTED 5784 /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 6055 /var/run/dbus/system_bus_socket
osmc@RaspiMultimedia:~$
And about the firewall thing,i don´t know where to see,if you can tell to me
Your firewall is configured to drop all traffic not in an active filter. In the list you have shown there are no active filters for port 8080 or port 5900.
You will need to seek advice from whoever manufactured your router as to how you can configure if for such traffic.
The fact that you can connect from inside your network shows that OSMC is working correctly. The iptables -L
command shows that you have no firewall rules to block external traffic and the kodi webserver by default accepts connections from anywhere so this can only be a problem on your router or with your ISP.
i will try to configure something in firewall,thanks
Last thing: can´t do anything for increase WIFI speed?
The speed of any connection in to your network will be a factor of many limits.
- The speed of the connection to the remote device.
- The “uplink” speed of your internet connection.
- The local network speed of the interface you’ve chosen.
Typically 2 is the slowest (even if 1 and 3 are WiFi) as most domestic internet is ADSL (A means Asymmetric - ie you get more downlink than uplink).
You may well find it is no faster remotely with link 3 as a cable.
If WiFi is the limiting factor move the RPi as near to the router as possible (at least in the same room) and choose a channel with no other WiFI hotspots on it.
How to choose a channel? sorry for so many questions,you can close topic if you want,but if you can help me,please help D:
It varies from router to router, check with your router provider.
ok,close topic…thanks
To monitor which channel is best for your network, use a software for android like this Wifi-Analyzer, look for the channel with the lowest curve, or even better no curve at all, and use that channel.
