My password for ssh has changes without an action of my part… I cannot connect on my OSMC in ssh. My password was registered in keepass, so impossible to be wrong.
Is there a solution to pass through the problem without re-install all the OSMC. I’ve got too many automatic script that are only on the raspberry…
I find it. Here’s how
1 - mount sdcard on linux
2 - launch the comand md5pass [my_password]
3 - note the hashed paswword
3 - edit the file file /media/[user]/[ID-device]/etc/shadow
4 - replace the line
osmc:[HASHED_PASSWORD]:16894:0:99999:7:::
by
osmc:[MY_HASHED_PASSWORD]:16894:0:99999:7:::
5 - save the file
6 - umount sdcard
Glad you sorted it, I’m wondering if something has changed today as I’m getting an incorrect password error on 2 remote devices (my parents and grandparents) that I’ve not copied the ssh-key to yet so I won’t be able ot access until I go and visit them.
Well if you have not changed it someone else has so suggest you:
Check how someone could have changed the password! Have you port forwarding from the Internet enabled? Did you change the default password? Any repositories installed which might have gained access to the system?
As your system my have been compromised and someone might have installed a backdoor suggestion is to start with a clean install
