Hey guys,
I’ve got a weird issue. My Vero 4k+ has stuttering issues when playing video content and wifi is enabled but not even connected. I’m connected via Ethernet. If I turn off Wifi it’s smooth again. The problem is that Wifi turns itself on once in a while and then I’m left in confusion why it’s stuttering again until I check if the Wifi enabled itself again. Any solutions to this?
Edit: Logs https://paste.osmc.tv/peyiherale
reproduce the issue
Sure! The Post is updated with logs now.
You’ve installed Network Manager, which will conflict with connman and seems to be causing some issues, such as starting WiFi.
May 27 10:40:13 MediaPlayer NetworkManager[270]: <info> [1590568813.8766] NetworkManager (version 1.6.2) is starting...
I don’t know how critical Network Manager is to your Docker installation, but it really should be removed.
I don’t remember ever installing it so I don’t know why it’s there. And I probably don’t need it. How do I get rid of it?
It was installed on 22 Nov 2019:
Start-Date: 2019-11-22 23:45:34
Commandline: /usr/bin/apt-get-real install network-manager
Requested-By: homeassistant (1001)
If you remove it, homeassistant might also be removed. You’ll need to give it a dry-run:
sudo apt-get purge network-manager --dry-run
It’ll tell you what will also be removed.
It worked thank you! Now having Wifi toggled on or off doesn’t make a difference either!
The dry-run option will simply tell you what it intends to do, but doesn’t actually remove anything. I assume that you also ran it without that option – and it didn’t remove homeassistant.
