My earlier Vero’s were integrated with my Control4 system such that the Control4 remote control worked for the Vero. The up-to-date Vero4K+ was fine. However, after upgrading to the Vero V this integration no longer works. Any thoughts? The IP address is unchanged. Have the Vero/Kodi control api’s changed with the new hardware? Seems unlikely…
The APIs for Kodi remote access have not changed. If you migrated your settings from the Vero 4K+ to the Vero V, in theory everything should be the same. If you set the Vero V up clean, you should probably check to see if you enabled all the remote access protocols and set the same username/password stuff in Kodi.
Should all be fine.
What version of Kodi is your older Vero running?
