Hi. I’m waiting for the arrival of my Ugoos AM6 Plus running CoreElec.
I’m gonna use that box for the secondary room.
Is there a way for me to copy or transfer Vero’s settings, skins and add-ons instead of manually setting them?
Thanks!
All that information are stored in /home/osmc/.kodi/ so yes you can copy the settings just need to figure out where they go on Coreelec.
Yes - you can copy the Kodi directory over. Be aware that CE implement things like multi channel audio a bit differently (it’s a separate device), so you will need to adjust some things there.
Thank you so much Sam and fzinken.
Will save me a lot of time specially with a very customized AEON MQ7 Mod skin on my Vero right now.
Cheers!
If you copy your userdata over and Kodi crashes on boot then you will probably need to delete .kodi/userdata/guisettings.xml. As that is the one file (that i’m aware of) that you can’t transfer between OSMC RPi and Vero installs I wouldn’t be surprised if it is problematic going to another platform.
Thanks for the heads-up mate.
Will just probably skip that folder.
I’m more concerned about the API Keys and Add-ons.
That would be rather counterproductive as the userdata folder is where those files are stored along with your sources, databases, artwork, etc.
