After a Summer power cut, I think my SDcard may be corrupt.
Im running OSMC December 2018 update on Pi Model2 with Sandisk 16G card
Every time I reboot my Pi, I get an error tring to read from
/dev/mmcflk01
This device does not exist and a reboot results in either a segfault or will boot nornally.
I have SSH access again and have uploaded grab-logs -A to:
https://paste.osmc.tv/uduhoxugox
I can remove SD card and run fsck.ext4 against the ext4 partition on my linux laptio but not sure how to check the fat32 partition.
Originally I bought MPG2 and VC1 license keys the commands:
osmc@osmc:/boot$ vcgencmd codec_enabled WVC1
WVC1=enabled
osmc@osmc:/boot$ vcgencmd codec_enabled MPG2
MPG2=enabled
State that the licenses are enabled. I remember appending keys to /boot/config.txt
but the contents of this file do not contain license keys. Could this be down to corruption?
osmc@osmc:/boot$ cat config.txt
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
Is there any other place license keys are stored?
If not I can play mpg files I will just order new license keys.
I can still access other logs t moment in case paste bin is insufficient.
Thanks in advance
