Cover Art / Fan Art loads extremely slow
after using the Alpha version of OSMC (RPI 2) for the last two years I finally got around to install the newest version. After scraping all my movies a few days ago I’m facing the issue that the cover art / fan art isn’t loading.
With previous versions it took always some time and a few rounds of scrolling through the library after setting up a new system until it properly worked. But with the new version it still doesn’t work correctly. It sometimes takes 5 minutes till the correct cover appears.
Any ideas how I can get this working?
Thanks!
I suggest you install the Texture Cache Maintenance Utitly
It has a function to cache all artwork automatically.
To install ssh into device run
curl https://raw.githubusercontent.com/MilhouseVH/texturecache.py/master/texturecache.py -o texturecache.py
then
chmod +x ./texturecache.py
To cache all artwork run
./texturecache.py c
Should be much faster then
Thank you for your quick reply. I will test it latest on the weekend and will let you know if it worked.
Thank you very much.
