I am trying to connect a USB serial logging cable from a weather station ( Davis Weatherlink cable ) and the OS is missing the driver.
After plugging in the cable, dmesg returns these 2 lines:
[ 1917.999902] usb 2-1: USB disconnect, device number 2
[ 1938.976526] usb 2-1: new full-speed USB device number 4 using uhci_hcd
lsusb returns these lines:
Bus 002 Device 003: ID 05ac:8241 Apple, Inc. Built-in IR Receiver
Bus 002 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
That 3rd line is the cable, so the system sees it but can’t do anything with it.
Doing some searches preliminarily indicates that the CP210x drivers should have been included in kernel builds for quite some time, but it isn’t in OSMC.
I have been trying to build it, but not having much luck for a whole host of reasons.
make -C /lib/modules/4.2.3-13-osmc/build M= modules
make[1]: *** /lib/modules/4.2.3-13-osmc/build: No such file or directory. Stop.
Makefile:4: recipe for target ‘all’ failed
make: *** [all] Error 2
I had to create the symbolic link for the build folder like this:
sudo ln -s /usr/src/atv-headers-4.2.3-13-osmc/ /lib/modules/4.2.3-13-osmc/build
That got me past the original make error, but now I get this error:
make[2]: *** No rule to make target ‘arch/x86/entry/syscalls/syscall_32.tbl’, needed by ‘arch/x86/entry/syscalls/…/…/include/generated/asm/syscalls_32.h’. Stop.
Great – to keep this driver enabled across updates, you should look at getting it included in OSMC. If you list the CONFIG_ options needed, I can look at getting it included.
