Crash on large seek (up arrow)
https://paste.osmc.tv/tusudigage
Moving this to forum since its no a confirmed bug…
With the latest update from today I am seeing crash (sad face) when I seek a video using the “UP” arrow, or chapter seek. using the left and right I am able to seek fine.
$ uname -a
Linux osmc 3.14.29-134-osmc #1 SMP Mon Dec 31 00:16:36 UTC 2018 aarch64
ii  vero3-mediacenter-osmc               18.8-19                        armhf        Media Center package for OSMC
here is the kodi.old.log log
mediainfo
General
Unique ID                                : 111202701161129046401537719651963017995 (0x53A8DC78040E01A86892F87529649B0B)
Complete name                            : MyMovie (2018).mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 13.6 GiB
Duration                                 : 2 h 23 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 13.6 Mb/s
Encoded date                             : UTC 2019-03-16 02:08:03
Writing application                      : mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit
Writing library                          : libebml v1.3.6 + libmatroska v1.4.9
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 9 930 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (23976/1000) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.200
Stream size                              : 9.94 GiB (73%)
Writing library                          : x265 2.7+15-b9f5b5d7bf95:[Windows][MSVC 1800][64 bit] 10bit
Encoding settings                        : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=24 / lookahead-slices=6 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=2 / subme=7 / merange=48 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : TrueHD
Format profile                           : TrueHD+Atmos / TrueHD
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Bit rate                                 : 3 579 kb/s
Maximum bit rate                         : 6 144 kb/s
Channel(s)                               : Object Based / 8 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            :  / 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Stream size                              : 3.58 GiB (26%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 2 h 14 min
Bit rate                                 : 33.2 kb/s
Count of elements                        : 2119
Stream size                              : 32.0 MiB (0%)
Language                                 : Chinese
Default                                  : Yes
Forced                                   : No
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Bit rate                                 : 18.6 kb/s
Count of elements                        : 2118
Stream size                              : 17.9 MiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Bit rate                                 : 34.7 kb/s
Stream size                              : 33.4 MiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #4
Format                                   : PGS
Muxing mode                              : zlib
Bit rate                                 : 20.3 kb/s
Stream size                              : 19.5 MiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : :绗?01 绔?
00:11:09.294                             : :绗?02 绔?
00:22:11.622                             : :绗?03 绔?
00:30:11.018                             : :绗?04 绔?
00:40:28.718                             : :绗?05 绔?
00:50:24.647                             : :绗?06 绔?
01:01:15.755                             : :绗?07 绔?
01:08:57.091                             : :绗?08 绔?
01:21:41.271                             : :绗?09 绔?
01:34:50.435                             : :绗?10 绔?
01:39:37.430                             : :绗?11 绔?
01:49:32.816                             : :绗?12 绔?
02:01:36.539                             : :绗?13 绔?
02:10:19.895                             : :绗?14 绔?
suspect its something to with the chinese chapter names, happens only in this video. i will get a sample together.
Can you replicate this with a stable build?
