Crash (sad smiley) while current playlist is visible
Hello!
My RPI model B rev 2. crashes (restarts after sad smiley) during music playback after the popup “loading media information from files” comes up. The music is streamed via wireless connection from NAS (SMB). This popup only comes up after about 10 songs were played and can be forced by skipping to next songs. I see no other problems during or after library updates: all info seems to be properly loaded in the playlists. The problem is not related to a specific song. The same setup runs under openelec without issues.
This is what I pulled from the log during the crash:
21:51:35 354.282715 T:3024527920 DEBUG: ------ Window Deinit (DialogVolumeBar.xml) ------
21:51:35 354.353516 T:3024527920 DEBUG: CGUIMediaWindow::GetDirectory (playlistmusic://)
21:51:35 354.354126 T:3024527920 DEBUG: ParentPath = [playlistmusic://]
21:51:35 354.361145 T:2703373296 DEBUG: Thread BackgroundLoader 2703373296 terminating
21:51:35 354.481903 T:2703373296 DEBUG: Thread BackgroundLoader start, auto delete: false
21:51:35 354.791687 T:2703373296 DEBUG: Thread BackgroundLoader 2703373296 terminating
21:51:35 354.799927 T:3024527920 DEBUG: RetrieveMusicInfo() took 318 msec
What could be causing this issue? Thank you very much for your support in advance!
Ok, I disabled “enable tag reading” in settings - music - file lists. It solved the problem. I’ve read similar problems on the Kodi forum.
