I have a problem with my raspberry pi 1 and OSMC. I have tried many times to install it to different SD cards and everytime it is installing all the files fine. When the installation finishes successfully, it reboots and crashes on the logo screen. The green led continues to blink though. I just lose the screen…
Maybe someone of you knows what might be the problem? The power supply is 5V 2.1A, so I believe that this would not be a problem. Actually one issue could be that I put the image to the SD card manually, because I have a Mac with El Capitan and I have the problem with the devices list using the OSMC installer. At this point, I should mention that Raspbian works fine without any issue with my Pi.
