I was wondering how do you customize the home screen on 17.4 with the osmc skin? For example, I want to click videos and it go to a specific addon. Thanks!
Are you saying this function is available in other skins but not OSMC?
I believe Titan skin is one that allows complete customization of home items.
You go to settings - Interface - configure skin - Customize Home Menu - Change Action
As well as the OSMC skin
Indeed, I guess I assumed that was not what OP sought or was something different than what I was aware of in Titan.
Let’s see but the example sounded like that
Thanks fzinken, will try that when I get home tonight!
[edited] It worked after reinstalling OSMC.
