Very top left corner on Kodi , I have 1 white pixel. This does not appear on other sources so the TV is fine. Any ideas as it’s quite distracting?
We’re aware of this issue and working on a fix. If we’re lucky, we’ve already figured it out, but it still needs some testing internally to be sure. In the meantime, a reboot fixes it (at least for some time).
This should now be fixed in the Debian Bullseye test thread.
Cheers for speedy response. Will test and let you know
Hi @sam_nazarko
All seems fine re the pixel after the latest update but after each boot I get a wall of text - see image - although it does boot fine after the delay and seems to function correctly.
It looks like you have an SD card attached that you might want to remove.
Nice one. That must have been in for years and I had forgotten about it!
