Since updating to the December update of OSMC I’m having issues with the NextPVR addon and LiveTV.
On first starting if i select a channel i will get a ‘Tuner no longer available’ error, if i then select another channel it will play fine. If i stop watching any channel and then start a channel again it will be fine. It seems to be only when first selecting a channel after a reboot.
We can help with playback issues, but this error is quite strange. I can’t think of obvious changes that would cause this. Can you check with the NextPVR guys?
