I did have a look around for the answer to this but couldn’t seem to find it. I have a bit of a convoluted folder structure on the HDDs plugged into my PI, so I was just wondering if there’s a way of setting up OSMC so that when I go to Video -> Files from the main menu it goes straight to a particular folder on one of the hard drives instead of displaying the root. I’d like to do the same for Audio too as all my music is in one place. Is that possible?
Generally you’re best off using the Kodi Library to organise your media and make it easy to access them:
http://kodi.wiki/view/Video_library
If you’re just browsing to the directories using Video->Files then you’re not taking advantage of this.
