After almost two years, hi again
I was using the Xonfluence skin, but yesterday decided to go back yo Estuaty, first the OMSC skin and then the classic one. In both, whenever I pressed the context menu to delete a file or a folder, the option wasn’t there. I looked over all the options available and couldn’t find it.
Would appreciate greatly if somebody told me how to get it back. In case it’s somethging that requires delving into the OS, don’t forget that I’m still alien to it, so a detailed process to follow would be most welcome. BTW, I use the Vero 4K+ remote.
Thank you
Wolfe
