I’m running Kodi 18.5 on OSMC 2019.11-1 on a Raspberry Pi 3.
It mostly works very well for me, as I generally switch it on, watch somethng then switch it off. However, When I switch on my RPi, if I wait for a few minutes (not exactly sure how long) before selecting the video, when I select the USB stick containing my videos, I get the OSMC animated logo and teh only way to clear it is to power cycle the Pi.
Any ideas what might be going on? I’ve posted the last few lines of my log file below (I don’t know how much is useful).
This is repeatable. The steps to reproduce are:
- insert USB stick contianing video files
- switch on Raspberry Pi
- wait 10 minutes
- browse to auto-mounted USB drive.
For me, it happens every time.
2020-01-19 20:38:18.713 T:1916163632 DEBUG: ------ Window Deinit () ------
2020-01-19 20:38:18.940 T:1895822048 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-19 20:38:18.940 T:1607410400 DEBUG: Thread Timer start, auto delete: false
2020-01-19 20:38:18.963 T:1916163632 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-19 20:38:19.188 T:1607410400 DEBUG: Thread Timer 1607410400 terminating
2020-01-19 20:38:19.212 T:1916163632 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-19 20:38:19.212 T:1916163632 DEBUG: HandleKey: return (0xf00d) pressed, action is Select
2020-01-19 20:38:19.212 T:1874850528 INFO: CActiveAESink::OpenSink - initialize sink
2020-01-19 20:38:19.213 T:1874850528 DEBUG: CActiveAESink::OpenSink - trying to open device PI:Both
2020-01-19 20:38:19.213 T:1874850528 DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:17640 bytes/s=352800.00 dest=PI:Both
2020-01-19 20:38:19.213 T:1874850528 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
2020-01-19 20:38:19.213 T:1916163632 DEBUG: CGUIMediaWindow::GetDirectory (library://video/files.xml/)
2020-01-19 20:38:19.213 T:1916163632 DEBUG: ParentPath = []
2020-01-19 20:38:19.214 T:1874850528 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x597c54e0
2020-01-19 20:38:19.214 T:1607410400 DEBUG: Thread waiting start, auto delete: false
2020-01-19 20:38:19.215 T:1874850528 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_splitter input port 261 output port 262 m_handle 0x59660d98
2020-01-19 20:38:19.216 T:1874850528 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x59781da8
2020-01-19 20:38:19.217 T:1874850528 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_splitter) - port(261), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(17664), nBufferAlignment(32)
2020-01-19 20:38:19.219 T:1607410400 DEBUG: Thread waiting 1607410400 terminating
2020-01-19 20:38:19.220 T:1874850528 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Output Device : HDMI and Analogue
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Sample Rate : 44100
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Sample Format : AE_FMT_FLOAT
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Channel Count : 2
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Channel Layout: FL, FR
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Frames : 2205
2020-01-19 20:38:19.220 T:1874850528 DEBUG: Frame Size : 8
2020-01-19 20:38:19.225 T:1607410400 DEBUG: Thread BackgroundLoader start, auto delete: false
2020-01-19 20:38:19.232 T:1916163632 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'noop'
2020-01-19 20:38:19.238 T:1607410400 DEBUG: Thread BackgroundLoader 1607410400 terminating
2020-01-19 20:38:20.292 T:1895822048 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-19 20:38:20.292 T:1607410400 DEBUG: Thread Timer start, auto delete: false
2020-01-19 20:38:20.317 T:1916163632 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-19 20:38:20.317 T:1916163632 DEBUG: HandleKey: down (0xf081) pressed, action is Down
2020-01-19 20:38:20.319 T:1916163632 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'noop'
2020-01-19 20:38:20.452 T:1607410400 DEBUG: Thread Timer 1607410400 terminating
2020-01-19 20:38:20.454 T:1916163632 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-19 20:38:20.500 T:1895822048 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-19 20:38:20.500 T:1607410400 DEBUG: Thread Timer start, auto delete: false
2020-01-19 20:38:20.504 T:1916163632 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-19 20:38:20.504 T:1916163632 DEBUG: HandleKey: down (0xf081) pressed, action is Down
2020-01-19 20:38:20.700 T:1607410400 DEBUG: Thread Timer 1607410400 terminating
2020-01-19 20:38:20.704 T:1916163632 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-19 20:38:20.980 T:1895822048 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-19 20:38:20.980 T:1607410400 DEBUG: Thread Timer start, auto delete: false
2020-01-19 20:38:21.019 T:1916163632 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-19 20:38:21.180 T:1607410400 DEBUG: Thread Timer 1607410400 terminating
2020-01-19 20:38:21.195 T:1916163632 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-19 20:38:21.195 T:1916163632 DEBUG: HandleKey: return (0xf00d) pressed, action is Select
2020-01-19 20:38:21.196 T:1916163632 DEBUG: CGUIMediaWindow::GetDirectory (/media/KDM32GB01/)
2020-01-19 20:38:21.196 T:1916163632 DEBUG: ParentPath = [sources://video/]
2020-01-19 20:38:21.196 T:1607410400 DEBUG: Thread waiting start, auto delete: false
2020-01-19 20:38:21.296 T:1916163632 DEBUG: ------ Window Init (DialogBusy.xml) ------
2020-01-19 20:38:59.133 T:1699730144 DEBUG: [Amazon] DB Update already running
2020-01-19 20:39:21.572 T:1874850528 DEBUG: CAESinkPi:Drain delay:99ms now:0ms
2020-01-19 20:39:30.231 T:1599017696 NOTICE: [Amazon] getURL:
2020-01-19 20:39:31.573 T:1874850528 DEBUG: CAESinkPi:Deinitialize
2020-01-19 20:39:31.573 T:1874850528 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
2020-01-19 20:39:31.579 T:1874850528 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_splitter handle 0x59660d98
2020-01-19 20:39:31.580 T:1874850528 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_render handle 0x597c54e0
2020-01-19 20:39:31.580 T:1874850528 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_render handle 0x59781da8
