Hi All,
I’m running OSMC on the Raspberry pi 7" touchscreen with Pi 2 Model B and I’d like to disable the touch feature and just use the monitors as a display.
Any know how to solve this problem?
I’d appreciate any help in this area!
Hi All,
As long as you’re running firmware from 30 November 2015 or later, just add:
disable_touchscreen=1
to /boot/config.txt and reboot.
