I’m new to OSMC (on Raspberry Pi) and quite liked the ability to switch off menu items I did not want to use (as I can in the Amber skin). However, I can’t find an option to do this in OSMC - is it possible?
Thanks in advance.
Thanks in advance.
It is. From the Home menu it’s under Settings > Appearance > Skin > -Settings > Home > Customise Home Menu
. From there you can delete any unwanted menu items. Hope this helps.
Great! Thank you.
