Hey there,
I got OSMC RC3 running on Raspberry Pi2. Works like a charm.
I use a pronto remote for my media stuff.
Would it be possible to get the discrete codes for OSMC ?
As a text file with the hex codes if fine.
Do you guys even have that?
Hey there,
Check in /etc/lirc/osmc-remote-lircd.conf - the hex codes are in there.
Cool thanks.
Found them
KEY_HOME 0x0F
KEY_INFO 0x10
KEY_UP 0x11
KEY_DOWN 0x13
KEY_LEFT 0x15
KEY_RIGHT 0x12
KEY_OK 0x14
KEY_BACK 0x16
KEY_TITLE 0x17
KEY_PLAYPAUSE 0x18
KEY_STOP 0x19
KEY_REWIND 0x1A
KEY_FASTFORWARD 0x1B
Now I need to translate that in binary… I think… I mean in 0000’s and 111’s…
Seems like real short codes… usually they are long as hell…
Got it!
KEY_HOME 0x0F 00001111
KEY_INFO 0x10 10000
KEY_UP 0x11 10001
KEY_DOWN 0x13 10011
KEY_LEFT 0x15 10101
KEY_RIGHT 0x12 10010
KEY_OK 0x14 10100
KEY_BACK 0x16 10110
KEY_TITLE 0x17 10111
KEY_PLAYPAUSE 0x18 11000
KEY_STOP 0x19 11001
KEY_REWIND 0x1A 11010
KEY_FASTFORWARD 0x1B 11011
Will try to import them in this afternoon.
The codes are outlined on the shop page:
https://osmc.tv/product/osmc-remote-control-for-raspberry-pi/
Out of curiosity: what are you using these for?
I use the codes on my Philipps Pronto TSU6000 that I bought 10 years ago and I still can’t find anything better.
Harmony remotes suck balls, excuse my language.
I keep an old white imac just to be able to program it (PPC). You program every button UI and code associated to the button.
Pic of my main screen where I press the TV, turns on everyone. Then pressing the device I want to use, turns it on and selects it and goes to it’s pages. Extremely responsive and RF, not IR. (it translates IR into RF). Love it.
I still need to reprogram the KODI page with new text, etc… Once the HEX codes work, I’m good to go
How does it have Blu-ray and Spotify icons if it’s 10 years old?
Does it get updates?
Yes, I update it when I get new toys… blu ray about 10 years ago, sounds right…
Spotify, I click on it and it selects my amp, then the proper input, then selects the spotify app out of all the proposed streaming services on my amp.
All updates are made by me. If I change TV’s, I need to re program with new codes. But there is a big community out there. http://www.remotecentral.com
All kinds of themes available
I used this one
Of course, if I had to re do it, I would go with their latest remote. But my Pronto has served me well. Got 2 extra ones on eBay for $50 with extra brand new batteries also.
I have all psd files that the author gave me a while back so I can edit anything in any way.
