Hi there!
I use my Pi together with Hyperion and yesterday I realized that this didn´t work anymore.
I was lazy and did not turn my TV on but instead connected to it with the Android Kore app and did a restart.
It did restart but Hyperion still did not work as I could tell from the wrong LED lights so I left it as it was.
Now the Pi (Modell B) hangs at startup. It shows the OSMC boot screen and freezes while displaying one of these lines:
(1 of 2) A start job is running for samba server (40s / no limit)
(2 of 2) A start job is running for LSB: start Samba NetBIO nameserver (nmbd) (26 / 5min 1s)
What is this? Hyperion still starts as I can see from the LED. Whats broken??
To get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload some logs. You can learn more about how to submit a useful support request here.
I don´t think, I can give you more information/logs because the system doesn´t boot full so I can´t access them!?
Well if you can not access via SSH nor Terminal. Not much you can do other than a reinstall
Finally I found time now to look up for this problem…
The Pi is available for ping/ssh for a couple of seconds until it freezes with one of the mentioned messages.
I can still read the SD card so maybe there is something that helps?
I´m pasting just three files here. Maybe something wrong configured?
config.txt
[quote]arm_freq=850
core_freq=375
gpu_mem_256=112
gpu_mem_512=144
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
dtoverlay=lirc-rpi
sdtv_aspect=3
gpu_mem_1024=256
dtparam=gpio_in_pin=18
sdtv_mode=2
dtoverlay=spi-bcm2835-overlay
dtparam=gpio_out_pin=17
dtparam=spi=on
decode_MPG2=*****
hdmi_force_hotplug=1
config_hdmi_boost=2
[/quote]
cmdline.txt
install.log
[quote]Thu Jan 1 00:00:11 1970 Starting OSMC installer
Thu Jan 1 00:00:24 1970 Detecting device we are running on
Thu Jan 1 00:00:24 1970 Mounting boot filesystem
Thu Jan 1 00:00:24 1970 Trying to mount to MNT_BOOT (/mnt/boot)
Thu Jan 1 00:00:24 1970 Using device->boot: /dev/mmcblk0p1 and FS: fat32
Thu Jan 1 00:00:24 1970 Preseed file found, will attempt to parse
Thu Jan 1 00:00:24 1970 Found a definition for storage: sd
Thu Jan 1 00:00:24 1970 Creating root partition
Thu Jan 1 00:00:24 1970 From a root partition of /dev/mmcblk0p2, I have deduced a base device of /dev/mmcblk0
Thu Jan 1 00:00:24 1970 Determined 255 MB as end of first partition
Thu Jan 1 00:00:24 1970 Calling mkpart for device: /dev/mmcblk0 and fs: ext4 with start 257M and end 100%
Thu Jan 1 00:00:26 1970 Calling fmtpart for partition /dev/mmcblk0p2 and fstype ext4
Thu Jan 1 00:00:50 1970 Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=2 blocks, Stripe width=1024 blocks
944704 inodes, 3775232 blocks
188761 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=3867148288
116 block groups
32768 blocks per group, 32768 fragments per group
8144 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: 0/116 done
Writing inode tables: 0/116 done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: 0/116 2/116 4/116 done
Thu Jan 1 00:00:50 1970 Mounting root
Thu Jan 1 00:00:50 1970 Trying to mount to MNT_ROOT (/mnt/root)
Thu Jan 1 00:00:50 1970 Using device->root: /dev/mmcblk0p2
Thu Jan 1 00:00:50 1970 Extracting files to root filesystem
Thu Jan 1 00:00:50 1970 Starting extract progress…
Thu Jan 1 00:08:07 1970 Extraction of root filesystem completed
Thu Jan 1 00:08:07 1970 Configuring bootloader
Thu Jan 1 00:08:07 1970 Configuring bootloader: moving /boot to appropriate boot partition
Thu Jan 1 00:08:21 1970 Configuring boot cmdline
Thu Jan 1 00:08:21 1970 The revision for this device is
Thu Jan 1 00:08:21 1970 Configuring /etc/fstab
Thu Jan 1 00:08:21 1970 Successful installation. Dumping log and rebooting system
[/quote]
Did you try to connect by SSH?
Yes. I can connect but only for a few seconds until it freezes
Only option is re-install then.
