Disclosure: this post was written by Claude Opus 5.5 (xhigh effort), which also did the log analysis and the RPU investigation, wrote the script and created the test file. I reviewed it and can answer questions or run further tests on my Vero.
TL;DR: My Vero V’s Dolby Vision metadata parser rejects RPUs whose CRC32 happens to end in 0x00, although the CRC is correct. That’s about 1 in 256 frames of any Dolby Vision title. With a profile 7 FEL movie (see logs), playback stopped after the fourth rejection and Kodi returned to the menu after a freeze timeout. I’ve had this with quite a lot of files. A synthetic test file (link below) reproduces the rejections exactly, though not the freeze on a manual run afterwards.
Setup
- Vero V, OSMC 2026.05-2, kernel 4.9.269-93-osmc, vero5-mediacenter-osmc 21.3.0-7 (Kodi 21.3)
- Vero V → Denon AVC-X4800H → LG OLED77G4, certified HDMI cables; 2160p24, TV-led Dolby Vision
- MKV files on a NAS via NFS (network and files ruled out, see details)
- Logs: https://paste.osmc.tv/rimenezudo (the failed playback is at 2026-11-02 00:03 to 00:05)
What happens (UHD Blu-ray remux, Dolby Vision profile 7 FEL; resumed at 13:26, stopped about a minute later)
00:03:50 kernel: DOLBY ERROR: meta(386), pts64(820194000) -> metadata parser process fail
00:04:04 kernel: DOLBY ERROR: meta(386), pts64(834250000) -> metadata parser process fail
00:04:13 kernel: DOLBY ERROR: meta(386), pts64(843301000) -> metadata parser process fail
00:04:30 kernel: DOLBY ERROR: meta(386), pts64(859567000) -> metadata parser process fail
00:04:36 kodi: CVideoPlayerAudio::Process - stream stalled
00:04:50 kodi: VideoPlayer: eof, waiting for queues to empty
Cause: the four rejected frames are exactly the ones whose RPU CRC32 ends in 0x00.
| pts64 (s) | frame | RPU CRC32 |
| 820.194 | 19665 | 0x0c123f00 |
| 834.250 | 20002 | 0xca09df00 |
| 843.301 | 20219 | 0x1502bf00 |
| 859.567 | 20609 | 0xfe492000 |
- They are the only such frames in the part that played, and none of the roughly 1,300 other frames produced an error.
- The CRCs are correct (checked for all 147,148 RPUs of the file), and dovi_tool and FFmpeg 9 parse these frames without complaint. Otherwise they are ordinary mid-shot frames.
- My guess (unverified): something strips trailing
0x00bytes from the RPU before it reaches the parser, which cuts off the last byte of the CRC.
Reproducing it without movie content: Dolby Vision P8.1 RPU CRC test pattern.mkv (1.9 MB, download: gofile.io/d/MbUHfUSD) is fully synthetic: an FFmpeg test pattern with generated Dolby Vision profile 8.1 metadata. 28 of its frames have a valid CRC ending in 0x00, at 5.005 s and then every 2.002 s, and each of them has a red border. On my Vero, all 28 are rejected at exactly those timestamps, and no other frame is:
12:40:06 kernel: DOLBY ERROR: meta(194), pts64(5005000) -> metadata parser process fail
12:40:08 kernel: DOLBY ERROR: meta(194), pts64(7007000) -> metadata parser process fail
... every 2 s, 28 in total ...
12:41:00 kernel: DOLBY ERROR: meta(194), pts64(59059000) -> metadata parser process fail
On screen, the video plays normally and the red-border frames show up every 2 seconds without any visible glitch. The 60-second file (video only) also plays to the end, so the rejections don’t always stop playback. I can’t tell what turns them into a stop with the movie (FEL, the audio track, the length or something else).
Any Dolby Vision title should also trigger it within a minute or two; the script in the details lists the frames to expect.
Possibly related: Vero V stops playback on Dolby Vision HEVC remux, with the same error and playback stop (meta(194) there, the same value my test file produces).
Possible workaround (untested): play affected titles with Dolby Vision disabled, so only the HDR10 base layer is used.
Details: logs, checks, test file, script
Kernel log around the playback
00:03:35 enable_fel 1
00:03:36 Creating Dolby Vision metadata parser instance success
00:03:36 DV:[0,805847000,12,DOVI,392,1]
00:03:50 DOLBY ERROR: meta(386), pts64(820194000) -> parser process fail
00:03:50 DOLBY ERROR: meta(386), pts64(820194000) -> metadata parser process fail
(the same pair for 834250000, 843301000 and 859567000)
00:04:50 vdec_release instance 000000003350e65c, total 2 id = 0
00:04:50 enable_fel 0
Ruled out
- Network: no NFS errors or retransmissions during playback, and the same part of the file reads at about 98 MB/s on the Vero.
- File damage: an ffmpeg demux pass over 12:00 to 16:30 is clean, and every RPU CRC is valid.
- HDMI: the errors come from the metadata parser on the Vero, before anything goes out over HDMI, and they follow the frame data exactly.
The file: Dolby Vision profile 7, level 6, BL + EL + RPU (BL compatibility ID 6), CM v2.9, 147,148 frames. 616 of its RPUs have a CRC ending in 0x00, roughly one every 10 seconds. The first three rejections were survived; playback stopped right after the fourth.
meta(N) is constant within a file but doesn’t follow the RPU size by a fixed offset: 386 for the movie’s 362-byte RPUs and 194 for the test file’s 164-byte RPUs (unescaped). So I can’t tell what it measures.
Test file: 2160p23.976, HEVC Main 10, HDR10 base layer, Dolby Vision profile 8.1 (CM v4.0), 1,440 frames (60 s) in 15 shots of 4 s. The trigger frames (120, 168, … 1416) are all mid-shot. All frames differ only in Level 1 avg_pq (1600 to 1900); the triggers use 1676 and 1839, which produce a CRC ending in 0x00. Made with dovi_tool generate (per-frame frame_edits), ffmpeg -f lavfi testsrc and libx265, dovi_tool inject-rpu and mkvmerge.
Checking any file:
ffmpeg -i input.mkv -map 0:v:0 -c:v copy -bsf:v hevc_mp4toannexb -f hevc - | dovi_tool extract-rpu - -o RPU.bin
python3 rpu_crc00.py RPU.bin # add the frame rate as a second argument if not 23.976
RPU.bin from dovi_tool is in display order, so frame N is at N / fps. The kernel’s pts64 is in microseconds.
#!/usr/bin/env python3
"""List Dolby Vision RPUs whose stored CRC32 ends in 0x00, and verify each CRC.
Input is an RPU.bin from `dovi_tool extract-rpu` (display order).
Usage: python3 rpu_crc00.py RPU.bin [fps] (fps defaults to 23.976)
import sys
def crc32_mpeg2(data):
crc = 0xFFFFFFFF
for b in data:
crc ^= b << 24
for _ in range(8):
crc = (crc << 1) ^ 0x04C11DB7 if crc & 0x80000000 else crc << 1
crc &= 0xFFFFFFFF
return crc
def unescape(buf):
"""Remove HEVC emulation prevention bytes (00 00 03 -> 00 00)."""
out, zeros = bytearray(), 0
for b in buf:
if zeros >= 2 and b == 3:
zeros = 0
continue
out.append(b)
zeros = zeros + 1 if b == 0 else 0
return bytes(out)
path = sys.argv[1]
fps = float(sys.argv[2]) if len(sys.argv) > 2 else 24000 / 1001
rpus = [r for r in open(path, "rb").read().split(b"\x00\x00\x00\x01") if r]
hits = 0
for i, r in enumerate(rpus):
if r[:2] == b"\x7c\x01": # strip NAL header if present
r = r[2:]
rbsp = unescape(r).rstrip(b"\x00") # 0x19 prefix ... crc32 (4 bytes), 0x80
body, stored = rbsp[1:-5], int.from_bytes(rbsp[-5:-1], "big")
if stored & 0xFF == 0:
hits += 1
t = i / fps
ok = "valid" if crc32_mpeg2(body) == stored else "MISMATCH"
print(f"frame {i:6d} {int(t // 3600)}:{int(t % 3600 // 60):02d}:{t % 60:06.3f}"
f" pts64 ~{round(t * 1e6)} crc {stored:#010x} ({ok})")
print(f"{hits} of {len(rpus)} RPUs have a CRC32 ending in 0x00")
Output on this movie (excerpt):
frame 19665 0:13:40.194 pts64 ~820194375 crc 0x0c123f00 (valid)
frame 20002 0:13:54.250 pts64 ~834250083 crc 0xca09df00 (valid)
frame 20219 0:14:03.301 pts64 ~843300792 crc 0x1502bf00 (valid)
frame 20609 0:14:19.567 pts64 ~859567042 crc 0xfe492000 (valid)
616 of 147148 RPUs have a CRC32 ending in 0x00
