Duplicate Automounts
Hi all,
I added an external HDD to my Raspberry Pi 4 system and imported the movies.
After a few reboots the system now states that the movies cannot be located when I click on them - asking if I want to remove them from the library.
I noticed that the drive is shown in the settings, but that it is not possible to open the drive. Below the drive is another couple of duplicate drives - the last one being a working link to my HDD.
It appears that the system thinks that the HDD is a different one to the one it is expecting - hence the links all break - then it mounts the drive as if it’s new but without the contents being mapped.
Am I doing something really stupid ?
I really appreciate any help you can give.
Jay :slight_smile:
Boot without the HDD attached and check for directories (there shouldn’t be any - just a README file). sudo rmdir any directories and re-boot.
