DV Movie playing in 8bit
Hi, I have a vero v (thks for the work on DV FEL)
When playing a dolby vision movie from jellyfin with the kodi addon :
Dune part 1 :
Bit depth10 bit
Video rangeHDR
Video range typeDOVIWithEL
DV titleDolby Vision Profile 7.6 (HDR10)
DV version major1
DV version minor0
DV profile7
DV level6
DV rpu preset flag1
DV el preset flag1
DV bl preset flag1
DV bl signal compatibility id6
Color spacebt2020nc
Color transfersmpte2084
Color primariesbt2020
Pixel formatyuv420p10le
It direct play (no transcoding, great)
but when i display info from my tv i get RGB complete with 8 bit depth
from /sys/class/amhdmitx/amhdmitx0/config i get :
$ cat /sys/class/amhdmitx/amhdmitx0/config
cur_VIC: 93
cur_video_param->VIC=93
cur_video_param->colordepth: 8bit
para->colorspace: 444
AVIF VIC: 93
VIC: 93 3840x2160p24hz
Colour depth: 8-bit
Colourspace: RGB
Colour range: full
EOTF: SDR
YCC colour range: full
Colorimetry: BT709
PLL clock: 0xdb0104f7, Vid clock div 0x000a739c
Aspect ratio: 16:9/full frame
DV type DV-Std
Is this normal, shouldn’t it display yuv 4:2:0 10 bit ?
When playing hdr10 movie it says correct info, only dolby vision seem to produce this result.
TV led DV is tunneled through 8bit RGB. What’s shown to you has nothing to do with the actual bit depth of the DV content itself :blush:
thanks, for the info
