Dear all,
I have OSMC on a RPi3 and after last update my dvb dongle is not recognized. Here the error from dmesg:
usb 1-1.3: dvb_usb_v2: 2nd usb_bulk_msg() failed=-110
dvb_usb_af9035: probe of 1-1.3:1.0 failed with error -110
is there anybody with the same problem?
Does it work in your computer? The probe issue suggests there may be a problem with the dongle itself
I haven’t made adjustments to DVB in this update
Ciao,
the dongle works in my computer (Debian). Is the kernel changed?
The kernel was bumped, but CONFIG_ options haven’t.
You shouldn’t have an issue probing the the device. This could happen if the power supply cannot provide enough power to the dongle.
Grazie Sam,
I have use it for several months without any problems and the power supply is an original Raspberry one…is it possible that last release of OSM ask more power?
I can’t think of anything that would take an increasing amount of power if updating from May to June.
