DVD iso playback issue
Hello all,
I searched the forum already but coudn’t find a solution.
I recently bought the Vero V, before I was using a RP4 with osmc.
it played back .iso dvd files fine.
I looked at the debug logs but can’t find a solution
#working RP4
Playback at 11:01:14.600
at https://paste.osmc.tv/ogidujoxaq
#Non working Vero V
Playback at 12:11:32
https://paste.osmc.tv/derefabexa
All help appreciated
Philippe
What’s the issue? No video output at all?
exactly doesn’t start at all.
Looks like the ISO may be encrypted, is this the case?
There are also some issues reading the ISO
2025-01-18 12:11:33.684 T:2941    debug <general>: OnAVChange: CApplication::OnAVChange
2025-01-18 12:11:33.684 T:3041    error <general>: CDVDInputStreamNavigator: Stopping playback due to infinite loop, caused by badly authored DVD navigation structure. Try enabling 'Attempt to skip introduction before DVD menu'.
2025-01-18 12:11:33.684 T:3041    debug <general>: Read - Demuxer for file /mnt/media/3_movies_FR_NL_EN/A christmas carol/A Christmas Carol.iso is at eof, removed it from the queue
Out of curiosity, does going to Settings → Playback and changing MPEG2 hardware acceleration to HD and up change anything?
"Out of curiosity, does going to Settings → Playback and changing MPEG2 hardware acceleration to HD and up change anything?’
didn’t change anything unfortunately.
also disabling hw mpeg acceleration didn’t change anything.
Not sure if that iso is encrypted
I think it’s an issue with the ISO if other files from the same source work.
The ISO seems to indeed be encrypted
well it doesn’t work with quite few .iso which worked before on the rp and osmc running on that system. so would like to get it running again on the Vero
How did you rip the ISO?
long time ago with MDRP I think.
Can you send me an ISO so I can test it here?
Sure let me send you a DL link
Philippe
I replied to your welcoming me on the forum
regards,
Philippe
Thanks. I am downloading the file. I think it will take a bit of time.
Take your time nothing urgent
normaal I have 100Mbit uplink so should go fast
I think it’s slower as it’s going through a Synology reverse proxy.
I cannot obtain the file via the link you provided.
ok thanks for the help, don’t know what is happening used to work fine ;(
Will transcode to mkv
thanks
Did it work? Do you have any other affected files? If you do and can share the file I can fix it
Hey Sam,
sorry super busy for the moment. Most of iso files didn’t work.
