Does OSMC skin populate emby nodes automatically?
I’m afraid not, no.
Something you might wanna add? Love the skin
Does this rely on the embuary helper addon like it seems to be the case with the Embuary skin?
I’m not 100% sure. But it seems like that in the wiki, also usable for other skinners Home · sualfred/script.embuary.helper Wiki · GitHub
Will have a look once there’s time. I’m very busy at the moment and switching from skin helper to embuary script will be a bigger piece of work.
So, no promises. It’s on the list, but it’s not a high priority at this point.
Really appreciate it. If you’re not using emby just let me know if you need testing.
