How do you mean?
Since the error points to a possible problem with the SD (memory) card, Iâd suggest trying a new one.
Out of the four power supplies currently plugged into the board they are rated the following:
5.1V 2.5A (official raspberry stamped plug)
Another one that is the first except US plug
5.2V 3000ma powering external hard drives
12V 2A also providing power to the hard drives through an official raspberry pi usb hub.
Tried the update mentioned by Sam (post #3) in this thread:
however it did not work for me! Just used
watch vcgencmd measure_temp
and noticed my pi is running at 61.2âC.
At the moment it is still 27.6âC in Adelaide (South Australia).
Installing and running lshw displays the following
osmc-tobias
description: ARMv7 Processor rev 4 (v7l)
product: Raspberry Pi 3 Model B Rev 1.2
serial: 00000000f3b2e353
width: 32 bits
capabilities: smp
*-core
description: Motherboard
physical id: 0
*-cpu:0
description: CPU
product: cpu
physical id: 0
bus info: cpu@0
capacity: 1200MHz
capabilities: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32 cpufreq
*-cpu:1
description: CPU
product: cpu
physical id: 1
bus info: cpu@1
capacity: 1200MHz
*-cpu:2
description: CPU
product: cpu
physical id: 2
bus info: cpu@2
capacity: 1200MHz
*-cpu:3
description: CPU
product: cpu
physical id: 3
bus info: cpu@3
capacity: 1200MHz
*-memory
description: System memory
physical id: 4
*-usbhost
product: DWC OTG Controller
vendor: Linux 4.9.29-13-osmc dwc_otg_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 4.09
capabilities: usb-2.00
configuration: driver=hub slots=1 speed=480Mbit/s
*-usb
description: USB hub
physical id: 1
bus info: usb@1:1
version: 2.00
configuration: driver=hub maxpower=2mA slots=5 speed=480Mbit/s
*-usb:0
description: Generic USB device
physical id: 1
bus info: usb@1:1.1
version: 2.00
configuration: driver=smsc95xx maxpower=2mA speed=480Mbit/s
*-usb:1
product: RTL2838UHIDIR
vendor: Realtek
physical id: 5
bus info: usb@1:1.5
version: 1.00
serial: 00000001
configuration: driver=dvb_usb_rtl28xxu maxpower=500mA speed=480Mbit /s
*-network
description: Ethernet interface
physical id: 2
logical name: eth0
serial: b8:27:eb:b2:e3:53
capacity: 100Mbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autone gotiation
configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverver sion=22-Aug-2005 duplex=full firmware=smsc95xx USB 2.0 Ethernet ip=10.1.1.193 li nk=yes multicast=yes port=MII speed=100Mbit/s
You are clearly missing the wifi, so I believe hardware issue (or power)
This is how lshw shows the wireless interface (shows DISABLED as i disabled it in config.txt)
*-network:0 DISABLED
description: Wireless interface
physical id: 2
logical name: wlan0
serial: b8:27:eb:81:06:6c
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=brcmfmac driverversion=7.45.41.46 firmware=01-f8a78378 multicast=yes wireless=IEEE 802.11
So I so look in the âconfilg.txtâ filr for comfimation?
I doubt any issue with your config.txt (I just wrote that to not confuse with the âDISABLEDâ) but you can recheck.
As mentioned I guess hardware issue unless you get it reliable shown with a clean install of raspbian or OSMC.
Yeah, I just tested it but using the Raspbian image from my other pi that has both the Ethernet and Wifi work. However, when I put sd card in the OSMC pi only Ethernet comes up when I scan for the ip address using a scanner whereas on the other pi addresses for both Ethernet and Wifi show up.
So hardware issue
