Enable wifi under GUI
Same problem here, the command line isn’t recognizing my Realtek adapter
I have this same adapter, but am having further problems. I’ve been able to successfully get to the point where it is connecting after submitting my Passphrase, but the connection fails every time.
Hi, tried setting up WIFI on my Pi2 with connmanctl with no luck. Currently using Ralink Technology, Corp. RT5370 Wireless Adapter .
   [    7.234397] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   10.686012] Console: switching to colour dummy device 80x30
[  224.367083] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[  224.477522] usb 1-1.2: config 1 interface 0 altsetting 0 has 7 endpoint descriptors, different from the interface descriptor's value: 5
[  224.484789] usb 1-1.2: New USB device found, idVendor=148f, idProduct=5370
[  224.484812] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  224.484830] usb 1-1.2: Product: 802.11 n WLAN
[  224.484846] usb 1-1.2: Manufacturer: Ralink
[  224.484861] usb 1-1.2: SerialNumber: 1.0
[  224.591827] cfg80211: Calling CRDA to update world regulatory domain
[  224.767074] usb 1-1.2: reset high-speed USB device number 5 using dwc_otg
[  224.877776] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[  224.906926] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[  224.923428] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[  224.925371] usbcore: registered new interface driver rt2800usb
Have the same or very similar adapter with same chipsets and also not working.
Just an update. This is my wifi dongle:
Bus 001 Device 006: ID 050d:2103 Belkin Components F7D2102 802.11n N300 Micro Wireless Adapter v3000 [Realtek RTL8192CU]
It doesn’t work as expected (miss my network SSID on services list)
Hi, my Wifi USB device is working but I cannot connect to the network when I am trying to I get the following message:
 connmanctl> scan wifi
 Scan completed for wifi
 connmanctl> services
 *AO Wired                ethernet_b827eb4bac06_cable
 *A  Liselotte            wifi_74da38007536_4c6973656c6f747465_managed_psk
 connmanctl> connect wifi_74da38007536_4c6973656c6f747465_managed_psk
 Error /net/connman/service/wifi_74da38007536_4c6973656c6f747465_managed_psk: Input/output error
My wifi seem to not get powered at all :frowning:
any suggestions?
dmesg result here
 connmanctl> technologies
/net/connman/technology/wifi
  Name = WiFi
  Type = wifi
  Powered = False
  Connected = False
  Tethering = False
/net/connman/technology/ethernet
  Name = Wired
  Type = ethernet
  Powered = True
  Connected = True
  Tethering = False
connmanctl> enable wifi
Error wifi: Operation timeout
Not working… Pls check.
Yes, we know, you said that already.
Does your SSID have a SPACE in the name? if so it is a known issue @ultramaximum
No, it’s an uppercase one word SSID.
I’m using channel 13.
Hi DBMandrake,
Worked like a charm for me (Pi 1 B Alpha4) Edimax RT3070.
Thank you
Pls fix it.
Try revisiting WiFi now with Release Candidate. Learn more at
Just tried RC version, below Wifi dongle still not supported, looks like drive not added. Pls fix it.
Edimax ew-7811utc ac600
Chipset Realtek 802.11ac (rtl8812au)
Edimax 7811 150Mbps is working. …
8812au support is in now. So this is likely vid/pid problem
S
May be, but its not working. Do you need VID/PID for this model ?
-P
8192eu is not working too. Can you include that driver in the final release?
VID=0bda PID=818b
Edimax EW-7811Un does not work too. Thank you.
Hi having issues with D-Link DWA-121 it the dongle has power but cant find my network works under old raspmc but not in OSMC finds my phone if i turn on hotspot any clues to why it cant find the wifi network when the older OS finds it ?
